microwave fan came on by itself
lolcoconuts
Chicago, IL
APYDMR0163
Frigidaire
Less than 1 year
I was making dinner and not running the microwave and the fan came on without out me pushing the fan button. The fan was blowing harder than it normally does if it were set out high. I tried to push the fan button to turn it off and then used the cancel button. The only way that I could get it to go off was to pull the plug. After about 5 mins I plugged it back in and the fan worked as normal. It is currently unplugged now. Why would this happen, and how do I get it to not happen again?
It might have a stuck thermostat or the heat from below closed the thermostat to close and the fan started. If it's less than a year old, call Frigidaire for a warranty service call. If you attempt a repair you could void your warranty.
