That's correct.
Nope. Read post #60. The monitor door switch is a deadman switch. It's designed to keep the microwave from working if the door is open by shorting L1 and N together. If the primary switch doesn't open before the monitor switch closes, the fuse blows. Make sure you have the switches wired correctly and the wires are on the correct switch terminals.
Rick, Thanks for your prompt respond, we're really appreciated.
We tested continuity while the switches are in the holders and tested good but still say DOOR on display.
Is there a way to test the wires or connections from switches to the board? It seems to me that we might have a bad connection from switches to control board. I re-seated all connections to the board again. Clock and Oven are in operation. We could turn Oven on/off and we were able to set the Clock.
I took the pictures of old connections before swapped them out. They should be correct but I attached them here for your review.
Thanks again for taking the time on this. We really appreciate your trying to help.
