Microwave/oven combo problem - Microwave and oven come on at same time!
jfischer
Houston
I' ve got a Oven/Microwave combo unit from Kitchenaid. When I try to use the microwave it reads DOOR on the control panel and it wont work even thought the door is closed to the MW. When I put on the oven, it comes on but I also hear the MW on and the fan above the MW also comes on. If I put water in a glass in MW while the oven is on it gets hot so I assume the MW is coming on with the oven control. Also nothing ( turntable, etc ) works in the MW when it heats the water.
Any ideas? Bad control board?
Any ideas on where to get the service manual for this unit?
Model #: KEHC309JSS
kitchenaid link to model
http://www.kitchenaid.com/Cooking/Built-in+Ovens/prodk/src__Built-in+Ovens--cat__124--prod__125
John
