FIXED Microwave turntable makes clunking sound
tobewan
Evansville, In
FGMV173KQA
Frigidaire
My microwave just started making a clunking, popping sound when operating. If I remove the turntable motor arm or turn the turntable off, it sounds fine (no unusual noise). It heats fine. What would be causing the motor arm to catch and clunk or whatever it's doing to make the noise? How can it be fixed? Thanks!
Toby
tobewan
Evansville, In
Not the motor...
Jeff,
Replaced the motor and still clunking. Guess it must be the roller support... Only failure mode I see there is the shaft slipping in the center of the support, is that likely?
Toby
If cracked or worn...you can see the + or X where they mate together...
tobewan
Evansville, In
Sorry to take so long but found a used roller support, changed it, and it does not clunk like the original one did.
Toby
