Miele H4080BM Stops Heating after Cleaning Door
nszzya
USA
H4080BM
I removed the front glass panel of our Miele H4080BM to clean the glass. The door assembly and hinges were untouched. After replacing the glass panel, the oven will not heat in microwave mode. The lights, display and timer all work. It is a combination oven and the bake function still works. I switched off the breaker for several hours but the problem persists. I have trouble believing that something has failed coincident with the door cleaning, so I'm looking for any suggestions before pursuing a more significant part failure.
Thanks for any help!
