MMV6180WS1 Maytag Microwave inside question - cardboard cover
Nashville
Nashville TN
MMV6180WS1
Hello folks.
I installed a Maytag convection microwave oven over the range unit.
Its been a year or so.
We really only use the microwave function.
When the microwave door is open look inside to the right and there is a cardboard piece screwed to the wall.
It looks like the piece should be removed but I left the piece attached because the set up instructions didn't say to remove.
I removed the piece today and it looks a vent.
My question is should I remove the cardboard or does it need to be attached to the wall during use??
Thanks for any and all comments in advance.
It's a cover for the wave guide. It sits in front of the magnetron tube.The microwaves come through it and helps spread them evenly.
Rcraig
Anderson, indiana
I burned popcorn in my microwave, while going through the cleaning process I broke that cover popping it out. Is there a safe way to put it back together or can I purchase a new one
