FIXED Model GSS26C4XXB03 ice maker tray not filling with water
pstruhar
michigan
GSS26C4XXB03
Hello,
I'm definitely a novice but I'm trying to troubleshoot my ice maker. I ran diagnostic 25 - water dispensing and ice maker fill test. I had previously filled the ice maker with water manually. After running the diagnostic, the ice was harvested from the tray but the tray wasn't filled with water. Digit 1 always showed 0 indicating the ice maker valve was off. It never showed 1 to show it was ever on which makes sense. Where do I go from here? Any help is appreciated. Thanks!
Let's check for the easiest problem that it can be first, lots of members have found frayed and broken wires causing the ice maker to be dead or not put water in the ice maker tray. Remove the black wire harness loom too, broken wires can be underneath it.
Another member was having a similar problem here: FIXED: GSF26C4EXY02 Whirlpool Gold Ice Maker Problem
Look at his post #6 he found frayed and broken wires underneath the freezer door, I'd remove your kickplate and check for that first.
Here's another one with the same thing about the frayed and broken wires: FIXED: 106.51173310 Kenmore elite ice maker not working - no led light
Here's another: FIXED: Whirlpool WSF26C2EXF01 Door Icemaker Not Working
WPW10251076 Icemaker
pstruhar
michigan
I've been busy so I haven't been able to check for frayed and broken wires...it's been on my list. Yesterday, the fridge made a couple batches of ice and now seems not to be working again. It's been around three weeks of no ice, then a little ice, and now no ice. What would make that happen??
The frayed and broken wires, you'd need to check that first before replacing parts.
pstruhar
michigan
Yep...broken wires. It's so close to where they go into the door I don't know if I have enough wire to properly fix it.
Yup, I see them broken in your photo. Glad that was all it was. (y)
You can solder extra wire to lengthen it with more slack.
