FIXED MRT318FZDE00 Maytag Evaporator Freezing Up
JacobJHofer
Platte SD
MRT318FZDE00
Good Morning
I Have A Maytag MRT318FZDE00
The Evaporator freezers up about Every 1-1/2 Months
I Changed the Main Board Still Does it What else Can I Do
Inside the freezer coming out from the back wall.
JacobJHofer
Platte SD
the Thermal Fuse is Good
the Heater ohms out @ 37 OHMS is that Enough
what is the Heater Part Number? I think I will just change it
The defrost heater is perfect at 32 ohms, don't waste your money ordering a new one.
I'm attaching your tech. data sheet below, get into the Service Diagnostics Mode and do the tests in Table 1, then look for Load Failures in Table 2.
  • tech-sheet-W10872127-RevA.pdf
Then you must of got a bad control board, where did you get it at?
Here's the control board for your model: WPW10674683
It's much less expensive when you order the complete assembly here: W11353815
JacobJHofer
Platte SD
I put in a New Control Board again and i Still cant get in the Service Diagnostics Mode
so that Board is bad to
the Way I'm Trying to access the Service Diagnostics Mode is pushing the Temp Set switch and the door Switch at the same time, thats right Right?
Ok Jacob where are you getting the boards from?
The tech. data sheet tells you how to access the Service Diagnostics, if you are doing it properly you are getting bad boards.
JacobJHofer
Platte SD
The Appliance Store that i Work for Orders em from Somewhere,I really Dont Know Where i Will order one from your Website see if that will work
I need to see a photo of the evaporator coil. Take a photo of it and upload it here.
Both please.:)
JacobJHofer
Platte SD
here you go
Perfect, thanks!
See your evaporator thermistor on the 2nd photo, on the top right side that's clipped onto the top of your evaporator coil? See the white connector that connects to it? It looks like its burnt there, take that connector off and see if the contacts inside that connector are burnt. If not burnt, then you will need to ohm test that evaporator thermistor, because if that's bad then that's what's causing this frost build-up problem.
This is how we test the evaporator thermistor--->WHILE ITS FROSTY, your freezer evaporator thermistor should read about 8.7K ohms. Always Unplug the refrigerator first before ohm testing.
If it's not frosty put in a glass of ice water and wait at least 5 minutes before ohm testing it.
Here's the freezer evaporator thermistor for your model:
WPW10383615 Thermistor
Excellent Jacob, glad to hear the new freezer evaporator thermistor fixed it.(y)
