FIXED MSD2650HEQ Maytag Water Dispenser Issue, vibrating
So your saying the filter bypass isn't letting the water flow to the ice maker and water dispenser anymore now at all?
I always pull the refrigerator out from the wall, then turn the water off, remove the water supply line, then get a bucket or container to catch water in to test the water pressure from the water supply line into a bucket, then turn the water supply line on, and it should have good water pressure force coming out in the bucket or container.
If your water pressure is good, then disconnect the water line tubing underneath the water inlet valve and then press the water dispenser lever and see if water comes out good directly from the water inlet valve.
Pinball_Dr
Bradenton, Florida
Have you seen a bypass cap go bad?
I pulled the housing to take to the parts store to match it, reconnected it at the sink to try it. As I would install the bypass, it would vibrate and allow some water to flow. If I put the cap on part way I could get a slow flow. Twist it on fully, it would stop. I used a spoon to push on the 2 white points the ramps on the inside of the cap would depress and got a pretty strong spray.
Nope.
Did you install the new filter housing?
Susieg
New jersey
Hi there! Maytag Ice 2o model MFI256AES will dispense about a cup of water or so and then make a very loud vibrating/Thumping noise and stop dispensing? Any ideas? We have tried replacing the filter.
Pinball_Dr
Bradenton, Florida
Nope.
Sorry, I did not make myself clear there. As the hour was late on Saturday, I was not able to go by the parts supply to buy anything. I will not be able to get new parts until Tuesday.
1) I do not have any spare parts at this time to install (filter, input housing, nor bypass cap)
2) The filter housing with by pass attached, will allow water to flow out of the inlet hose, but not into the refrigerator. Tried this both on and off refrigerator.
3) When I had housing out and water line attached, I could get water from the input line to the output line by slowly twisting on the bypass part way. It would often vibrate as the water came out slowly (water line to housing was good pressure) and stop when cap was fully twisted on.
3a) there is a soldered in threaded T connector after the under sink cold water valve, not a piercing type
4) When I pressed on each of the white tips that the inside ridges of the bypass would press on as it was tightened down, there was a strong spray from each tip.
This led me to question about a bad bypass cap.
Thank you for all your time in this, Scott
Ok Got it, now I'm clear.:)
Yes, from that information you just posted the NEW water filter housing should fix it. The new water filter housing also comes with a new bypass cap.
But if you don't plan to ever use a filter why don't you just permanently bypass it with a John Guest fitting? Then you won't even need to purchase that filter housing at all.
Look at post #13 here: https://www.applianceblog.com/mainforums/threads/51763-Water-leak-around-filter-housing/page2 Rick gives the 3 different options in sizes.
Pinball_Dr
Bradenton, Florida
I just cut the input line to about 2.5 foot long so there would be little chance of it kinking, and looped it back to the tank line. Works great!! Thank you. :))
Excellent, good job.:)
TexasHandyMan
Houston
For anyone else having this problem first take off your water filter and you will see two spring loaded plunger valves on the water filter housing where your water filter twist into place. These two spring loaded valves are what prevent water from flowing when the water filter is not in place. Next, with the water to the refrigerator off, take something like a thin screw driver or allen wrench and depress each plunger valve all the way in and back out several times. This will clear out what is most likely some calcium deposits that are built up inside. Replace your water filter. Turn on water. If this fixes your problem then just say nice things in your mind about the anonymous guy on the internet that just saved you 2 hours of your life. LOL Hope this helps.
