- MVWB765FW0
- Maytag
- 1-5 years
Hi-Looking for some help troubleshooting Maytag top load washer MVWB765FW0. Usually with heavier loads (towels, jeans, etc.), rinse cycle continues to repeat at around 30 min left. Timer gets down to 27-28 while draining/spinning, then resets back to 30 and fills the tub again. Does this about 3 times and then shuts off. I change setting to drain/spin and same thing happens. Starts at around 15 min, spins until about 10-12 min, then jumps back up to 15 and fills the tub again. Continuous cycle until washer shuts off. (The spin cycles do not get to those high speed spins.) I go into diagnostics mode and get error codes F9E2, F0E5, and F0E3. Sometimes it happens with regular clothes too. Already replaced water inlet valve as one of the solenoids had no continuity. I'm thinking it might be motherboard but hate to spend the $$ without being sure.
