- MVWB850YW0
- Maytag
- 6-10 years
Hi there!
Recently replaced the bearings/shaft and tub seal on my Maytag Bravos XLMVWB850YW0, and it no longer sounds like a jet engine when spinning, which I'm thrilled about!
Since I put everything back together, we've noticed a squeaking/chirping noise that happens during agitation only, and seems to be when the washerplate/agitator is changing directions. I've taken a few videos and attached them to show the noise during a wash cycle, and believe I've managed to replicate it by moving the washplate back and forth by hand. There is no noise during spin cycle.
I've since removed the wash plate and the plastic hub kit beneath it, applied some of the green grease that came with my bearing kit to the shaft splines and inside the mating areas of the washplate and hub pieces. I was optimistic this would fix it but it hasn't made a difference.
Hoping someone may have experienced a similar issue or knows how to address this noise. Appreciate any advice!
