MVWC300XW0 Maytag washer not spinning
ezduzit99
Chicago Suburbs
MVWC300XW0
Hi all. I've been scouring the web trying to find resolution to this. Ran the diagnostics, which pointed toward a faulty shift actuator. Replaced that and still having the same problem. Haven't replaced the lock switch, as it appears to be operating normally. Any thoughts on what the
Hi, Let's check for a error code.
I'm attaching the tech. data sheet for your model below.
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
ezduzit99
Chicago Suburbs
I went ahead and replaced both the lid lock and control board, and recalibrated the machine. Everything seemed to be correct. Ran two wash cycles without issue. The next day, ran a third and the original problem occurred where it would not spin on the spin cycle. The F7E5 error code came up when I pulled the error code. Cleared the code, and ran the automatic diagnostic cycle. Checked and no error codes present. Seems to be working fine. For now. But I'm still concerned as it should have been fine after the board and lock were swapped. Any thoughts?
Sounds like a faulty shift actuator, where did you buy it from?
Here's the shift actuator for your model:
Shift Actuator WPW10006355
