FIXED MVWC415EW0 Maytag Centennial Washer won't spin
Bill1961
Prattville, Al
MVWC415EW0
My Maytag Centennial washer, works fine until time to spin. A few months ago I replaced the agitator plastic clutch , that was worn out, and it started working fine, now I have this problem. I turned over machine and looked at the belt clutch that goes into tub, nothing seemed loose, no nut off, everything was even from one end of belt to other end, but it makes this noise when it goes to spin, and it won't spin. It makes the noise like 3-4 times, and the stops, Could it be a slipping belt, nothing has dropped down, no nuts off that I can see. Any help would be appreciated, thanks.
Yes, Lets check your hub first.
Here's the hub for your model:
W10528947 Hub
Here's a video to access/replace it:
--->Look at these photos below of the hub teeth grinded down to smooth. It should NOT be grinded down to smooth.
Bill1961
Prattville, Al
I replaced the hub for Agitator a month ago. About a week after that I did have to go back inside washer and tighten bolt that is down at the bottom of agitator, must not have tightened good enough 1st time. I turned the agitator with my hand and it's not turning freely from the tub, like it was when it was stripped. Do you think the hub has wore out that quick. I guess it's possible, since it's plastic. I have tried not to overload the washer also, because the guy at parts store, said they get wore out, by overloading sometimes. It was a tight fit when I put new hub on. Put all the screws in, then tighten them down. I guess I could have screwed up, and caused it to strip out, it seemed like a pretty simple of a fix. Thanks Jake, for your reply, I will go back in tomorrow, and check hub again.
Yes, especially if its a aftermarket hub, you can only use the OEM hub on these machines. Where did you buy the hub at?
What part store? In your local area? They only sell OEM parts?
Yes, check the hub again today to see if its smooth.
Bill1961
Prattville, Al
I went yesterday and got another hub, before I saw your reply. I haven't pulled out of package. A1 Appliance Store in Montgomery, Al is where I got it from. Not sure if it's aftermarket or OEM part, I will check with them today. They said I probably was putting to many clothes in washer, but I have not been overloading washer since I replaced the 1st time. It could be an aftermarket part. Thanks for the info. Well I don't need to call them, I just checked the part number you gave, and on the package, and they are both the same, so it must be OEM.
Bill1961
Prattville, Al
I put the new hub on, and recalibrated the washing machine, something I didn't do the 1st time. Thanks for your help Jake. Hopefully this one will last a little longer
Ok Bill, yes that hub looks OEM to me too.:)
Glad to hear your back in business.(y)
