MVWC425BW0 Maytag Stopping on Random Cycles
NY
MVWC425BW0
Greetings,
I searched by model number, but none came up, so not knowing if other related issues on other models is the same, thought I would ask.
My washer is randomly stopping at sensor cycles. I replaced activator sensor, no change, and I saw posts of resetting after replacing, but is this only on higher level models with diagnostics feature like the 500 model I was reading about. I checked lid switch, not dirty, so is this something to replace next?
Thank you,
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1psVH4VJFVWLEFo_Kf8Dwp9OlD8vPDuVG
Get into the diagnostic and post the fault code or fault codes you get.
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
