MVWC425BW0 Maytag Washer - very loud spin cycle and F7E1 code
scanman
Carroll County, MD
MVWC425BW0
Hi -
I purchased a used Maytag machine. Worked fine until my wife mentioned that sometimes it leaks a little bit of water, and there would be a squeal noise. I assumed this was happening during the spin cycle, but did not get to troubleshoot it further.
Meantime, my wife tried to wash a load of clothes, and the spin cycle became very loud. Thought there might be an issue with the suspension rods or leveling legs, but these looked fine.
Ran a diagnostic test and got two codes: F7E1 and F7E5. Cleared the codes. Ran "heavy agitation" in manual mode several times. Seems to work fine with no trouble codes. Both "low spin" and "high spin" seem to run in manual mode very briefly. Lid locked light flashes, and then I get the F7E1 code. The other code (F7E5) has not returned.
Did some research on this forum, and it looks like the problem is likely the shift actuator. Was hoping for some feedback before proceeding with purchasing a new shift actuator. Seems like this is a part that commonly fails on these machines.
Thanking you in advance,
Dante
For the banging you'd need new suspension rods and springs, they come all 4 in a kit:
Suspension
For the F7E1 That's usually the shift actuator.
Here's the shift actuator for your model(Video Included):
WPW10006355 Shift Actuator
Where is the water leaking at?
scanman
Carroll County, MD
Thank you very much Jake! (I will have to troubleshoot the water leak further once the parts you mentioned are replaced and the machine is more functional.)
Thanks again,
Dante
Ok Dante, sounds good.
Correct.
Glad to help!
