MVWX655DW0 Maytag bravos model wont agitate but spins
Dante334
Pittsburgh
MVWX655DW0
The agitator does not agitate and its makes a weird rubbing/grinding sound. It seems to spin fine. I've also noticed a few times where the clothes were still soaked after the cycle but that seems to be intermittent.
Be sure the washer is in standby mode (plugged in with all indicators off).
Perform the following sequence of movement using the cycle selector knob.
NOTE: After RESET sequence “a” through “e” must be completed within 6 seconds.
RESET - Rotate cycle selector knob counterclockwise one or more clicks to clear sequence.
A. Rotate cycle selector knob clockwise one click and wait ½ second.
B. Rotate cycle selector knob clockwise one click and wait ½ second.
C. Rotate cycle selector knob clockwise one click and wait ½ second.
D. Rotate cycle selector knob counterclockwise one click and wait ½ second.
E. Rotate cycle selector knob clockwise one click.
Successful activation of Diagnostic Test Modes will be indicated by all status LED’s (except for Lid Locked) flashing ON and OFF in half-second intervals. NOTE: LED names may vary between makes and models.
If the status LEDs do not display as described above, the sequence may not have been completed within 6 seconds.
To access fault/error codes, turn the cycle selector knob until the status LED’s or display correspond as follows:
Press the START button to enter Fault Code Display Mode.
The status LEDs will flash ON and OFF and “cl” is displayed on the 7-segment (if display exists).
To view last 4 fault codes:
Turn cycle selector knob clockwise to view fault codes in the order of most recent to oldest.
NOTE: A fault/error code will be removed from memory if it does not reoccur after 10 consecutive wash cycles.
To clear fault codes:
Turn cycle selector knob until the status LEDs flash ON and OFF or “cl” is displayed on 7-segment.
Press and hold START button for 3 seconds to clear all fault codes.
Press POWER to exit Service Diagnostic Mode.
Post the error codes here
