FIXED MVWX655DW1 Maytag Bravos MCT rubbing noise?
Twisted1
Bay Area
MVWX655DW1
Hi everyone. I joined this forum in hopes to find the solution for my problems. I have a Maytag Bravos MCT, and as of recently it began making a loud rubbing type noise when agitating a full load. This happened out of nowhere and began immediately. I ordered a replacement pulley kit for it from Amazon and replaced everything, and noticed about an hour later the nut to the pulley was loose. So I retightened it and tried again but the noise is still there when agitating. I’m at a loss at the moment. No error codes present..
Is there a certain torque spec for the pulley nut?
I’m not a repair tech for these machines but I do automotive repair so I am savvy. Cheers
We see a lot of problems from getting parts from amazon, those are mainly aftermarket parts and do not always work properly. Did it fix the rubbing noise?
Here's the OEM splutch cam kit for your model:
W10721967 Splutch Cam Kit
The pulley nut has to be super tight.
Twisted1
Bay Area
Hi Jake. I ended up calling a tech and the issue ended up being a stripped driven hub plate. I’m going to return the Amazon stuff and buy Genuine OEM.
You mean this hub below?
Here's the hub for your model:
W10528947 Hub
For others following your thread--->Here's a video to access/replace it:
Got it, thanks for confirming that.(y)
