MVWX655DW1 Maytag Bravos MCT washer Clothes Still Wet
jbnlwilliams
Buffalo, NY
MVWX655DW1
What I have tried;
1. I have removed Change from under the agitator.
2. I have replace the drive belt.
3. I have check the pump and all hoses for obstructions.
The water seems to flow quite freely from the machine. However, I now notice that the machine does not spin nearly as fast a it used to. Also, there is a Fluttering sound when it starts to spin. I have a video attached.. Any help would be appreciated.
Added model number
We would need the model number of your washer first. The model number tag is located underneath the lid.
It looks like your hub is bad. Check your hub to make sure the teeth are NOT worn down, if so, then that's the problem, order the hub.:)
Look at these photos below of the teeth grinded down to smooth. Let us know what you find.
Here's the hub for your model:
W10528947 Hub
Here's a video to access/replace it:
Ok, sounds good, keep us posted.:)
