MVWX655DW1 Maytag Bravos MCT Washer: Water level too high in wash cycle
Muligan
Jackson, MS
MVWX655DW1
When the washer is filling for the wash cycle, it fills too high. the affect is that it does not wash/agitate properly because the clothes float above the agitator plate. I have searched and search and cannot seem to find any other reference to this issue. Some discuss overflow, but that is not the case here. And, apparently, a decent service manual and a parts location diagram is a well guarded state secret. Has anyone run into this problem before? I thought it may be a sensing switch or something, but I have no idea where it would be. Some of my research suggest it may be the inlet valves (supposedly they have some type of flow/fill sensor in them ). Maytag service desk did not provide any useful information. Any assistance would be appreciated.
I'm attaching your tech. data sheet below, lets check and see what FAULT/ERROR CODES you get.
Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
