MVWX655DW1 Maytag Washer would run its normal cycle then it would get stuck with the spin light on
Rtufixer
Illinois
MVWX655DW1
Ok started having issues with this. Washer would run its normal cycle then it would get stuck with the spin light on.
Ran the codes came up with F2E1, F9E1 and F5E1.
So I cleared the codes ran the automatic test all worked until I got to the fill and drain part. It filled but didnt drain. Then went into manual mode tried to drain nothing. Now it shows no fault codes and still won't drain.
I'm afraid to try and start it from the beginning cycle. I'm thinking bad board at this time?
Go back into manual drain and measure the voltage at the drain pump.
Rtufixer
Illinois
Thanks for the reply. I ordered a new pump seemed like that might be the issue. If its a board whole machine is getting tossed not spending that kind of money when I can just get another machine.
It's one or the other. Didn't want to see you get stuck with a new part you don't need.
