FIXED My Whirlpool Refrigerator GC3NHAXVY01 condenser fan kicks on and off
Gump66
Missouri
GC3NHAXVY01
My Whirlpool side by side refrigerator seems to be cooling fine but the condenser fan kicks on and off at very short intervals. The coils have been cleaned with compressed air and I replaced the condenser fan motor, thinking that was the problem. It does exactly what the old one did. I am guessing possibly the control board or the compressor inverter. Any ideas?
Gump66
Missouri
Thank you for replying but when I put in my model number GC3NHAXVY01, it says this part is not compatible. I know that there is also a W10823804 but I've seen that is also not compatible with my model.
W10823803 is compatible for your model. AppliancePartsPros Compatibility Tool is not always up to date.
RepairClinic has the most up to date Compatibility Tool and I just confirmed it does work in your model:
Gump66
Missouri
OK. Thank you.
Glad to help.(y)
Gump66
Missouri
Got the replacement part that you specified and it fit perfectly. Very easy to replace and the directions were spot on. I did have a little issue with it running quite a bit and the freezer got way too cold but I unplugged it for a couple hours and it seems to be ok now. Thanks again!
Excellent, glad to hear the new control board service kit fixed it.(y)
Gump66
Missouri
After I put in the new control board service kit every thing seemed to be working fine. No more condenser fan kicking on and off. However, now my refrigerator side is getting too cold, down around 33. I put a separate thermometer in there to make sure and it also registers the same. The freezer side seems fine. I took the damper out, thinking that may be the problem. I can move the flapper but now sure how to test it. I did not have any issue with temperature control before putting in the control board service kit, just condenser fan issues. I have unplugged it several times and left it off for a couple hours, thinking maybe it needed to reset but no difference. Any suggestions?
Try setting the control to a warmer setting. Normal is 34° - 37° so you're only 1° off.
Gump66
Missouri
I've done that. Tried to set it numerous times. I just looked and the fridge is at 29. The temperature setting is on 45 and the freezer setting is at 4. I think my manual said that default settings are 40 and 0. I closed the damper door manually yesterday before putting it back in and it seemed to be ok for awhile but apparently the door opened again and does not close. I can constantly feel cold air blowing from the freezer when I put my hand up to the damper.
Gump66
Missouri
There wasn't some sort of reset procedure that need to be done after installing the circuit board service kit was there?
Measure the resistance of the FF compartment thermistor At room temp (77°) it should be 2.7K Ω
I was able to locate the tech sheet. Go into service mode and check the damper. You can also check the thermistors is service mode.
  • GC3NHAXVY01-tech sheet.pdf
Gump66
Missouri
Thank you so much. I will get back to you after trying this. Just got into the diagnostic mode and everything checks out ok except the evaporator fan motor gave me a 2 instead of a 1 but it looks like this has to be a visual check, I guess to see if the fan is running. It just shows that the damper door is open but could it be that it is not closing properly?
Gump66
Missouri
I took out the damper and watched it while I pressed the code number in service mode. I could feel the motor trying to turn it but it just vibrated. Since I like to tinker with things, I opened it up and the little plastic gears were stripped off.
I replaced the damper WP2220377 and the FF thermistor WP2188820 just for the heck of it. Refrigerator seems to be doing ok now and at least not freezing the FF now. It is staying at about 37 even though I do have the setting at 46. If it stays at that, I'm good.
Thanks for your help.
