NE58F9500SS/AC Samsung range broiler on in all oven settings
Brian T
Ontario Canada
NE58F9500SS
Samsung
Our samsung oven's broiler is coming on in all oven modes. I've tried resetting, which worked for a little while. Troubleshooting isnt showing any fault codes. Any help on where i should go with the troubleshooting from here would be greatly appreciated. I don't have any manuals for this stove.
Model number: NE58F9500SS/AC
Thank you in advance for any help you can give. Also Merry Christmas and Happy New Years.
Corrected model number
Merry Christmas and Happy New Year.
Unfortunately that model number does not pull up good here in the USA, its likely a Canadian Samsung, which we don't have any tech. data information for.
Hopefully a Canadian tech that's seen that model and seen that problem, can shed some light on it for you.
Brian T
Ontario Canada
Thank you for getting back to me Jake. Since you aren't able to help, do you know if there are any tech's on this site that do have info or of any canadian sites that offer the same information?
@Dan O. lives in Canada.
@jeff1 lives in Canada, but he's taking time off due to a emergency in his family.
I'll message Dan O. for you.
From the way most current ranges are built, that symptom would most often be caused by shorted relay on the electronic control or a relay board (if a separate component from the control).
I'm afraid I have no access to Samsung service info in the US or Canada. You might need to contact Samsung Canada or one of their service depots to see what they can suggest.
I will tell you that your model number looks incorrect. Samsung appliance model numbers usually start with 2 letters, NE... for electric ranges, eg. NE58F9500SS is a valid model number. (I don't know how an "N" could possibly be mistaken for a "5" though)
It's very important to supply accurate product identification as printed right on the appliance's model and serial number identification tag when requesting assistance.
Brian T
Ontario Canada
In response to your last message I've attached a pic with model and serial number.
Brian T said:
In response to your last message regarding the model number I've attached a photo with the model and serial number.
Yes, and it's different than what you posted in your first message. It's NE58F... not 5E58F... you supplied. (Now corrected by the webmaster)
Be sure to provide accurate information when you're asking for assistance or you'll get nowhere.
CDodd
Houston
Has this problem been corrected for you? We are having this issue right now. Thanks.
I found a copy of the service manual (in these forums!). While it doesn't describe that exact occurrence, by looking at the wiring diagram I can't see any other possible cause than a defective control relay board on the back of the range (not the display board in the control console).
One of the relays on that board may be shorted, keeping the broil element powered even when it shouldn't be.
LINK > NE58F9500SS Relay Board
Samsung Range Service Manual
BASIC: NE58F9710WS
MODEL: NE58F9500SS
MODEL CODE: NE58F9500SS/AA
Manual LINK > https://www.applianceblog.com/mainforums/attachments/ne58f9500ss_aa_130617_v02-pdf.32435/
RF_Burns
Ontario Canada
Just found this forum, sorry I'm a bit late.
FYI our NE58F9710WS oven started to randomly burn food just after the warranty ran out. Me being in electronics for nearly 50 years was not going to pay over $400 to have it repaired. So I did some troubleshooting and found the broil relay contacts were sticking. I found the exact relay on-line for about $3.00 apiece, so I ordered 3 to replace all the alike relays.
I then opened the faulty relay after installing the new ones and found the relay contacts badly burned. Very bad design to use a relay to turn ON/OFF a high power heating element several times a minute (PWM). Its been about 2 years now and the new relay is still working, but when it dies I'll looking into replacing it with something more reliable.
Thanks for the Service Manual download!
