NE58K9560WS Samsung Range Upper Fan Noise
enkoopa
NE58K9560WS
Samsung
NE58K9560WS, 4 years old. Upper convection fan has turned into a screaming banshee.
Is there a replacement for the whole unit? Or is it motor + blades + ??
enkoopa
Ahh damn. With a screaming banshee, any recommended steps before just replacing all the fans?
I took off the upper shroud in case it was something rubbing, still making the noise.
*If* the blade and nut will come off and can be reused, order both motors....use the obe you need and ship back the one you don't need.....or like you said, do both because if one went the other is likely not far behind.
Most noises that I see is the motor itself.
