FIXED NE59J7850WS - Control display flickering, code dC and possible uneven cooking
rustingrooster
Springboro, Ohio
NE59J7850WS
Samsung
My NE59J7850WS aa "02" samsung duo-flex electric range just started having flickering on its display. Here is a video:
Symptoms:
  • Flickering / flashing display.
  • The clock and the oven picture display are the most affected.
  • The timer and temperature of both ovens flicker less.
  • ~Maybe~ some uneven cooking in the top oven, things on the left side are cooked more than the right.
  • Oven temperature seems about 25 degrees low when measured with a cheapo oven thermometer. It also seems kind of slow to come up to temp.
  • Diagnostic code shows is 0 - dC - which I think is for the dual oven divider switch.
Tried already:
  • Checked continuity of the divider switch and it appears to be OK.
  • Unplugging the unit for an hour did not change anything.
  • Checked the 240v connections and they are secure on the back of the oven - including the ground.
  • Have also checked the other connectors on the main board and the sub board and found nothing loose or disconnected.
This unit has a main board, a sub board, and the LCD display and I'm having trouble deciding which one to replace.
Any help you can provide will be greatly appreciated. Thanks in advance.
Ok, sounds good.
(y) Excellent, glad to hear the new LED Display Board fixed it.
