Fluelikesymptoms
- NED4600YQ1
- Amana
- 6-10 years
I had a prior thread where the dryer was getting to hot because of a cycling thermostat. Replacing that thermostat fixed that issue a few months ago. However a new problem has started, it wont heat at all.
The readings I have so far
9.8 ohms of resistance on the heating element
.05 ohms on the thermostat
.07 ohms on the cycling thermostat
Lately I have started to not trust continuity readings so I did the unsuggested
There is 120volts going into and out of the heating element, with a voltage drop of .001v between the two ends.
I also have about 112volts going into and out of both thermostats.
This thing should be heating and it's not, its ice cold. The heating element is not getting hot at all, I'm started to think it has gone bad somehow even though everything is testing fine.
What would be the next thing to check for?
