NED4655EW0 Amana Dryer Timer advances but won't shut off and will not heat up either
ogwog
IN
NED4655EW0
Amana
Woke up yesterday to find dryer still running but no heat. Made sure the vent was not clogged and there is air flow. So the dryer will not heat up in the timed or auto settings.
The timer does advance on the timed setting but when it gets to zero, it will not shut off.
Sounds like the dryer timer is bad. Put it on AIR FLUFF/NO HEAT then see if the timer turns everything off when it gets too OFF.
Here's the timer for your model:
W11043389 Timer
