Need help/guide - how to replace front manifold panel on 30" GE Cafe C2S986SELSS Dual Fuel Range - Part # WB36X28215 (see pic)
gecaferange1983
MI
C2S986SELSS
Less than 1 year
Hello, any help is greatly appreciated on how to replace/remove the front manifold panel on my GE CAFE Dual Fuel range...the top was damaged/dented..believe the correct part # from a breakout is # WB36X28215, please correct me if wrong...
Also, how easy is this, how do the front knobs come off..any tips or tricks involved, would prefer to not break other stuff/caution when doing replacement.
Thank you in advance! Glad I came across this website
Your missing a digit in your model number. Read it from the model number tag on the machine.
Click here: Appliance Parts
Here's the results I get:
C2S986SEL1SS
C2S986SEL2SS
I couldn't locate the service manual for either of those models. Yes, the knobs usually just pull off. Then look for screws underneath the manifold panel, if not underneath then pull the range out a little and look for screws on the ends of each side of the manifold panel.
You can also click here--->WB36X28215
Then you will see a Questions and Answer Section there, you can ask them if you don't find any screws to remove. You may need to remove the complete top assembly.
Make sure you turn the power OFF to your range before you begin!
