imported post
I have a model SHU5306UC/U06
It fails to shut off. It does not drain. pressing buttons 2 and 4 simutaneously causes it to clear and drain. The cycle buttons do not seem towork properly. sometimes I will get a normal wash, sometimes it will come up rince and hold, therr is no predicting it. The delayed start alsoseems to have a mind of its own.It seems pretty clear that there is a problem with the circuit boards in the door. They may or may not be covered under the warranty, but the labor is not, $130 minimum.
So the question is, could there be some simple fix like a loose or corroded wire? Is there anything about this machine that is a common problem.
Can ther be any justification to spend a minimum of $130 on a five year old machine when a brand new one is three to four hundred dollars?
I thank you for any insights that you can give me.
