Need help with Kenmore Refrigerator 106.51129210 ice maker leaking
BillyA
Texas
Ice maker overfilling and freezing in ice container. Replaced the water inlet valve and now no water going to ice maker. Any ideas ?
After replacing the water valve, you need to bleed the air from the system by running about 2 gallons through the dispenser. You'll still have some air in the ice maker line. It can take as much as 3 harvest cycles before the water gets to the ice maker. After replacing the valve it usually takes about 24 hours for the ice maker starts producing ice.
BillyA
Texas
Ok got the air bled off and it started making ice again but it’s also overfilling and freezing in ice holder. Any suggestions ? This is the original problem and reason water valve was changed.
OK, it's overfilling the ice maker and the ice maker controls the fill time so replace the ice maker.
