FIXED Need service manual for Kenmore 106.51713410 - Ice Maker Not Working - Service test code 46
Bearrepair
Palm Springs
Icemaker not making ice, service test cycle code 46 displayed. I would really appreciate if someone happens to have the service manual for this model (S.no HR45008209)
Thank you in advance
I don't have the service manual for this model, but I did locate the tech. data sheet, I'm attaching it below. There is no service test 46. There is a STEP 46 in the tech. data sheet, but activates the water dispenser, not the ice maker.
If the ice maker is not working, it sounds like you may have broken wires. This has been very common on this model.
Lots of members have found frayed and broken wires causing the ice maker/and or auger motor to be dead. Remove your bottom kickplate grille, Remove the black wire harness loom too, broken wires can be underneath it.
Another member was having a similar problem here: FIXED: GSF26C4EXY02 Whirlpool Gold Ice Maker Problem Look at his post #6 he found frayed and broken wires underneath the freezer door, remove your kickplate and check for that first.
Here's another one with the same thing about the frayed and broken wires: FIXED: 106.51173310 Kenmore elite ice maker not working - no led light
Here's another: FIXED: Whirlpool WSF26C2EXF01 Door Icemaker Not Working
If the wires are good, then you'll need a new ice maker.
WPW10251076 Icemaker
  • Service and Wiring Sheet - W10679979 - Rev A.pdf
Bearrepair
Palm Springs
SOLVED. Thank you for manual! Just want to update on the fridge. Everything started to work good after icemaker replacement. Checked the wires under freezer door. Looked ok. Unfortunately this model doesn't have test cycle for icemeker. Newer Kenmore/Kitchenaid do have this cycle. Thank you again for providing the manual!
Excellent, glad to hear the new ice maker fixed it.(y)
