FIXED New Microwave turns on (doesn't heat) when gently pulling handle. Works fine otherwise.
Delfonik
Warner Robins, GA
JVM6175SFSS
Less than 1 year
Hi, I just installed a new GE Series OTR microwave; model JVM6175SFSS
When I pull the handle gently and not hard enough to open the door, the microwave turns on. The light inside comes on and the fan (not vent) turns on as well. However, the turntable does not come on and the heating element does not engage (When turning microwave on using the control buttons, I can actually hear the heating element engage after about 1 second. I do not hear the same sound when I gently pull the handle).
When I gently pull the handle, I hear a click. Once it clicks, it turns on, but without heating and the turntable. Has anyone come across something like this?
I called GE tech support, and they say it could've been an issue with the installation since I didn't have it professionally installed. I explained that the majority of the installation was installing the mounting bracket, and I didn't do anything to the microwave except mount it on the bracket and screw in the two top screws.
Most will, no cooking will occur but the fan/light will often come on......don't do that! ;)
Delfonik
Warner Robins, GA
That was easy!
Thanks for the reply Jeff. I tried searching before making a thread, but couldn't find any posts with the exact issue. My old microwave has a button to open the door, so this style is new to me.
Thanks again,
Del
Your welcome :)
