FIXED New WLP Model WFC150M0EB Poor Performance?
Ponchoguy
USA
WFC150M0EB
Less than 1 year
Jake:
My coworker bought one of these for her church. It is an electric stove. She said it takes forever to even boil water. I've been reading that some of these have a "reduced power" mode when the elements get too hot?
It's brand new, so she's going to have to check a few things. Someone reused the old cord from the previous oven, and I downloaded the book for the new oven and told her that she has to get a cord that matches the specs shown in the book. I wouldn't think the cord is putting it into "reduced power" model, what do you think?
Thanks.
No, a 3 prong cord will work on a range designed to use the 4 prong cord. The difference is a 4 prong cord has a separate ground wire. If you had a 3 prong cord on the old range then you had a 3 prong wall outlet. The 4 prong cord will not fit the outlet without changing it so it's common practice to use the old cord if whoever installed it didn't have a 4 prong outlet with him. It doesn't affect the range heating capabilities. The voltage is the same. The range is on a double 40 amp circuit breaker. Tell her to reset both breakers (turn them off then back on).
If she thinks there's problem with the range she should call Whirlpool and set up a warranty service call. Everything is covered for the first year. If you attempt a repair you risk losing the warranty.
Ponchoguy
USA
Thanks, Rick. I will pass it along. I agree, and I see from the paperwork they also have a 2 year extended service plan that was purchased with it.
Whirlpool makes good appliances and they have a good warranty. Be sure to tell her to reset the breakers. Keep us posted if there was a problem with the range
That's awesome bb! I didn't know that. Thanks for finding that! OK Ponchoguy, looks like there isn't any problems with her range. You can download the pdf and show it to her.
Ponchoguy
USA
Thanks to all, I am passing this on to my coworker. Yes, WLP makes good appliances. That's pretty much all I have in my house (including WLP made Kenmores).
Thanks again.
Ponchoguy
USA
Called WLP on behalf of my coworker and after some digging they "found" this bulletin that you referenced. As a result, they are sending out the revised service kit for free. I'll advise if it's better after the installation of the kit. Thanks to all who replied and for providing this information.
Ponchoguy
USA
My coworker received and installed the parts. The improvement is night and day and it boils water in ten minutes flat like it should. Thanks again for everyone's help, much appreciated.
I've seen newer GE and Frigidaire coil range top elements that have a built-in thermal cutout but those stop the whole element from heating should an overheat condition occur.
JFYI
Ponchoguy
USA
The installation of the kit was night and day. The stove was totally useless with the original parts, as it took 45 minutes to (barely) boil water according to my coworker. The new kit allows water to boil in ten minutes.
