FIXED NFW7200TW11 Amana washer will not spin or drain
danielle1
NFW7200TW11
Amana
will not spin or drain got the nd code and checked all the drain lines and pump no obstructions replaced the pump and still get the nd code and no spin or draining the water.
nfw2700tw
Won't come up for me....could that be NFW7200TW10 ?
If a washer cannot drain, it cannot spin....concentrate on the not draining.
Is the drain pump running?...getting power?
danielle1
Hey jeff1 there isn't any numbers at the end of the model # it just says NFW7200TW and 11773010PJ is the serial # if that helps it looks like power is getting to the pump but it isn't running didn't have a test meter so i used a test light.
Thanks for the help
Then it would be NFW7200TW11
Jeff should be back shortly to assist you.
NFW7200TW
NFW2700TW
Great, the 72 and not the 27.
If the pump is getting power but not running, that should be new drain pump time....
Model shows two different pumps used for the same model#...
Drain-Pump-34001340--01025659.jpg Drain pump. Re-use original mounting bracket from old pump. Manufacturer Number 34001340
Drain-Pump-W10175948--01338108.jpg Water pump Manufacturer Number W10175948
danielle1
I will pickup a test meter and see what it reads on the power to the pump.I can hookup the old pump to a 110 receptacle and it runs.
Since it wouldn't run in the washer and a test light just looks for line and not power, the pump may not actually be getting power :(
Great :)
danielle1
The voltage reading on the line to the pump was only .1 volt and .03 amps.
So is there a sensor or switch that control the power supply to the pump.
danielle1
Thanks for the help. Replaced the control board today and it seems to be working now.hopefully i will get another couple years out of it.
Thankx for the update :)
Dirty Clothes
Minnesota
Amana NFW 7200TW no drain
Revisiting this post due to same problem on same machine but different outcome. I replaced control board/panel and replaced pressure switch but still no draining. $200 in parts already in. Cleaned and tested pump and it works fine but still no draining. In service mode the pump won't come on either. I have cleaned out the pressure hose as well. Any other suggestions are much appreciated.
How was it tested?
What happens instead? Power to the drain pump, no power to the drain pump?
in service mode the pump won't come on either.
NFW 7200TW
I found NFW7200TW10 & NFW7200TW11
Dirty Clothes
Minnesota
I pulled the pump out and direct wired 120v and it worked fine, runs smooth. I did not test incoming wires for power. That will apparently be my next step. thanks -
Only trouble with that is the pump is not working very hard....it has no resistance to running....that can change when everything is full of water and it has to work harder to run and go.
Yupper, that is the place to start.
Dirty Clothes
Minnesota
AC Voltage should be 120 and I'm only seeing 9.5V and even that fluctuates. I saw 89V once when the pump should have been on pre-spin cycle. It seems that unless the MEMS module has anything to do with he program the only logical conclusion is the supposedly NEW control panel/board (ebay) is not any better than the one I removed.
Dirty Clothes
Minnesota
btw: I hooked the pump up directly to 120V with an external switch so I could drain the dirty water in the machine and it drains fine.
Certainly sounds more like a bad board, or a bad wire between the board and pump ( probably a good idea to ohm those to be safe )....and the MEMS board is -usually- only for off balances.
