NN-8N778S Panasonic microwave - carousel not turning
Billiam
Midwest City OK
NN-8N778S
Panasonic
The carousel in our microwave suddenly quit rotating a couple years ago. The oven still works well.
A start might be looking into the turntable motor under the unit. Checking it for continuity to see if it might be burned out is likely necessary.
LINK > How do I test for continuity?
If the motor did not test open, someone might next need to confirm if power was getting to it when it should be running. The motor used looks to be 120 volts.
LINK > Panasonic NN-SN778S Turntable Motor
If it was not even getting power, someone might need to look into the control system and wiring to the motor.
Billiam said:
You don't happen to have a link to a diagram on this do you?
No I don't.
Can it not be access from the bottom? That's how most are accessed.
