itsmdude
- WFW9150WW01
- Whirlpool
- 6-10 years
So I have an interesting problem that I thought some of you might be able to advise me on.
My Whirlpool Duet (WFW9150WW01) stopped in the middle of the spin cycle.
The door stayed locked. I powered off, ran diagnostics. got F8E1, cleared the code, powered off, ran a rinse cycle and it added water and then drained but didn't spin.
I powered off again and did a rinse & spin cycle without the extra rinse. It drained but didn't refill or spin
Ran automated diagnostic procedure and it stops at "door locked" -- no cold fill (which is the next step in the diagnostic).
At this point every time I try to run a cycle — no water. door locks and that’s it.
Will NOT unlock when I press pause.
Because I originally saw water go into the compartment, I checked the pressure switch, part #W10239066. Pins are numbered differently than the documentation. When I check #12 and 11 (1 & 3 as counted from the left when the hose nib is up) I have continuity. When I put air pressure on it, no continuity.
#14 and 11 (contacts 2&3) no continuity, but when I apply pressure, yes to continuity. So it seems ok.
Door lock: I do have continuity on DLS2-1 to DLS2-2 when it is locked, no continuity when it is manually unlocked so it seems like that’s working.
However, since I never saw water go in the compartment ever again, I checked the cold water valve (W10212596).
Continuity of VC2-2 to VH7-7 and VC2-1 to VH7-5 is fine on the harness.
Disconnected VC2-1 and VC2-2 from water valve to measure the voltage from the CCM, then ran diagnostic program, which should “Fill by cold water via bleach compartment” using VC2 and VC1 simultaneously.
Machine “off” measures .86V
Measured 11.24V during test
Did the same thing with VC1 to VH7-1, continuity is fine on the harness.
Disconnected VC1 from water valve, Checked VC1-1 and VC1-2 voltage measurement during diagnostic program.
Machine “off” measures .38V
Measured 10.7V during test
Because I saw voltage during the test, I assumed the valve was bad, so I replaced the valve.
However, I'm still having the problem. Now I'm suspecting the CCM. I don't know what the "right" voltages the CCM should be producing.
Can anyone confirm what voltage I should be seeing from CCM to the cold water switch (VC2 and VC1)?
Or, if you have other ideas, I'm all ears.
Corrected model number
