No heat 2 weeks after changing board
BlasphemousMonk
Orlando
Hey everyone,
Great website out here. It helped me identify that I needed a new board for my dryer. But not after running a handful of loads I have no heat. Dryer runs fine on timed dry and the even heat setting. I have read through the boards on different dryers and was curious if the boards could be damaged/defect? But I doubt it will be that simple. Thanks in advance for the help!
Ok, then your heat relay is fine.
If your dryer is getting 220/240 volts and just runs and no heat, then its either your thermal cut-off or element thats bad.
Unplug your dryer first.
Watch this video to ohm test the thermal cut-off, it will ohm the same as your thermal fuse:
<iframe id="yui-gen75" class="restrain" title="YouTube video player" height="390" src="//www.youtube.com/embed/3nicyh6EUHc" frameBorder="0" width="640"></iframe>
Or, You can jump it with an alligator clip or take the wires off the thermal cut-off and use electrical tape to tape them together to see if it starts heating. DON'T LEAVE IT JUMPED TO RUN A CYCLE, order a new one.
Its #47 on the side of the heating element housing:
http://c.searspartsdirect.com/lis_pn...6713-00003.png
Here's the thermal cut-off assembly for your model in case you need to order it:
Manufacturer's Number: 279769 is RepairClinic Item #2821
This video shows how to access it both parts:
<iframe height="390" src="http://www.youtube.com/embed/2bVoelV7M7Y?rel=0" frameBorder="0" width="640" allowfullscreen=""></iframe>
Here's the heating element for your model you can order here:
Manufacturer part#3387747 is RepairClinic item#525502
Watch this video to test it:
<iframe height="390" src="http://www.youtube.com/embed/wq-3zsiBID8?rel=0" frameBorder="0" width="640" allowfullscreen=""></iframe>
