No heat from Whirlpool Dryer WED4815EW1
Juniorjr
TX
WED4815EW1
Hello all,
As mentioned in the title I'm not getting any heat from my WED4815EW1 dryer. It does turn on, spin, turn off when I open the door, timer works fine. Tested the outlet, it is putting out 240V. Dryer vent/duct is clear. Pulled off the back cover of the dryer and tested continuity on all the things that I could find from my google search (heating element, thermal fuse, hi limit thermostat, thermal cut off) and all passed. Anything else I should check? Should I just start replacing those parts and see what works? Perhaps I have wired it wrong (4 prong outlet, picture below)?
A copy:
Q: My electric dryer runs but will not heat, what could stop my dryer from heating?
A: Things that could stop a electric dryer from heating: house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
Your pic looks wired ok but you will need a cable connector.
Tested the outlet, it is putting out 240V. - Perhaps I have wired it wrong (4 prong outlet, picture below)?
Is this a new installation?
220-240 volts ac from red to black. 110-120 volts ac from red or black to white.
jeff sr.
