grillmarkedX
- NTW4516FW2
- Amana
- 1-5 years
I have an Amana top loader that will not complete the wash cycle. It won’t drain or spin.
I did a lot of research and watched a lot of videos. I wound up taking the back panel off to make sure there were no clogs in the hose. I took the drain pump off and saw nothing clogged in there either.
I wound up just buying a new drain pump (a couple months later), and I usually don’t spend money on parts if I’m not 100% sure what the problem is. Seemed like it was worth a shot since there were no clogs and most research I did seemed to point towards the drain pump.
Anyway, I put the new pump on and it COMPLETED THE CYCLE from start to finish! (wash, rinse, spin). First time in months! Then I did a small load and everything still worked fine, once again it completed the cycle start to finish.
Cool, everything works now, right? Wrong! Next load was a regular load and I ran into the same problem— it won’t complete the wash cycle. It fills and agitates but won’t drain and/or spin.
Now, why is it that it wouldn’t complete the wash cycle, I put a new drain pump on and it works fine for 2 loads, and then during the 3rd load it stops and once again won’t complete the wash cycle (no drain/spin)??
I did do the diagnostic (L, R, R, R, L, R) today to see if that would somehow help and then tried to run a “normal” cycle but still no luck.
Any help would be appreciated. We’ve had this washer for a few years, but I’m not really sure how old it is since it was from rent-a-center.
