NTW4650YQ0 Amana Washer not spinning on regular cycle.
Missyd1130
Huntington, WV
NTW4650YQ0
Amana
My washer will only spin on Drain/Spin. I've already replaced the latch. What could possibly cause it not to spin out on a regular cycle?
When it should be spinning in the regular cycle what does it do instead? Do you hear any sound at all from it like its trying to spin? or is it dead silent?
I'm attaching your tech data sheet below. Get into the ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES and see what fault code you get.
On Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
tbenn
ny
Hello Jake,
I am new here & thank you for the great info. I have this same model washer & have had this same issue or similar 3 times now. The board keeps popping either the 22 uf or 1000 uf 6.3 volt capacitors after about a year. Any idea why this would keep happening? Thank you for all the great info here!
Tom
