NTW4651BQ0 Amana top load washer only fills on small load, all other load sizes just drain
Wendy Ordway
Maine
NTW4651BQ0
Amana
I did a diagnostic and also a manual reset by unplugging for a minute and opening and closing the lid 6 times in 30 seconds. It used to fill and work on small and medium. I did a diagnostic and large worked again for about 3 loads and now medium doesn't work? ANy advice would be greatly appreciated!!!
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1psVH4VJFVWLEFo_Kf8Dwp9OlD8vPDuVG
On page 17, TEST #6: Water Level
Since yours is doing fine on LOW, do just these steps below:
3. Unplug washer or disconnect power.
4. Remove console to access controls.
5. Check hose connection between the pressure transducer or switch and the pressure dome attached to the tub.
6. Check to ensure hose is routed correctly in the lower cabinet and not pinched or crimped by the back panel.
7. Verify there is no water, suds, or debris in the hose or dome. Disconnect hose from main control or pressure switch and blow into hose to clear water, suds, or debris.
8. Check hose for leaks. Replace if needed.
