NX58F5500SW Samsung oven won't back or broil
tsmith88
New York
NX58F5500SW
Samsung
A few days ago my oven and broiler quit working (two weeks after the warranty ended). The range works fine. When bake or broil is switched on there's no sound or heat.
It seems like this must be a control board issue since both igniters went out at the same time, but I'm not sure how to test that.
Any thoughts would be appreciated.
Tyler
Check for error codes:
Make sure the Timer and Warming Drawer are both turned OFF.
Touch the Clock pad.
Touch the number pads 1,2,3 and 4.
Touch the Start/Set pad.
Touch the ‘Clock’ and the ‘Touch to Wake-Up’ pads at the same time for 2 seconds.
Error codes are displayed. Press 0 to see the last 5 error codes.
Press the Off/Clear pad to return to normal display mode.
tsmith88
New York
Thanks, Rick. My control panel looks a little different and doesn’t have a touch to wake button. Do you know how I’d show error codes on this one?
