NX58H5600SS/AA Samsung Bake won’t work...again!
JLM-pdx
Oregon
NX58H5600SS
Samsung
About a month ago, the oven would intermittently not ignite. Then it completely failed. The broil function worked fine. Upon pressing “Bake” then “Start”, a clicking sound was audible. So I figured the igniter was bad and replaced it. Since then, it has worked fine. Today, the same thing is happening. A click is audible from the touchpad area, but the oven does not ignite. What is more likely? The part I installed was a bad part and failed prematurely or something else is causing the part to fail prematurely or the new igniter is okay, but some other part is bad? Thanks in advance!
JLM-pdx
Oregon
No, it is not. Exactly as before. I replaced it a month ago and it worked like a charm. Now, nothing.
Next step is to check at the ignitor for power....when the ignitor is not working and should be on but is not.
Power there and no glow = bad ignitor. No power there and you have another issue.
