Ou812mech
- WT7200CW
- LG
- 1-5 years
Hello,
Read many posts on same subject.
What I have:
Washer stopped and won't drain in spin cycle. No humming or noise at all from drain motor pump. Has OE msg. No auto-drain function works after 4 min. Even get "dr" msg for auto-drain, but drain pump still doesn't turn on. Dr lock function is good.
What I've done:
Called LG which was no help at all, except the agent connected me to "All Brand" appliance. All Brand referred me to "Encompass.com" where I downloaded a service manual--big help!
Per service manual, I cannot enter the "SVC" troubleshooting/diagnostics mode of washer after pressing and holding "Temp" and "Soil" buttons. Can't enter "Test mode 6". Drain hose is clear. I shop-vacumed washer contents thru end of drain line.
Have 115vac across blue and grey drain pump wire connectors. Drain pump motor ohms out at 11.5 ohms. Removed pump, no blockage. Put it on a bench and hooked up an old lamp plug wires to it, and it runs ok. Replaced it anyway with new oem drain pump--exactly the same. No help. New pump on bench is a little "smoother" than old one as far as vibration goes, but they both work. Put the old one back in.
Service manual mentions the pressure switch and the tygon tube air chamber connected to it. Part number 6501ea1001. Air chamber tube is clear. Pressure switch ohms out ok at 23 ohms. I did remove switch and shaking it around, I could hear some loose rattling inside. Opened it up and a small "something" fell out which I could not find. Small piece of plastic maybe? Put it back together and hooked it up.
Some questions/observations:
Should I replace this pressure switch anyway, even though the washer didn't give me a PE code for the pressure switch? And I don't think I should hear the loose rattling? How does this pressure sensor/switch work? Does it simply sense water level rising in the closed loop tube which builds up air pressure in tube?
I will do some closer wiring checks like broken wire at plastic terminal ends.
Confirm there's no drain filter or water exit valve on this model? So as far as the water level goes with this washer, it acts sort of like a plumbing S-trap or P-trap whereas the water level in the drain line is at the same level as the water level in the washer tub?
Thanks in advance!
Gordon
What I have:
What I've done:
Thanks in advance!
Gordon
