Old Maytag needs help
drsprackland
Oregon
LA112
My washer will spin, and will flush water, but does not let water in. I removed the filter units and cleaned them well (they were pretty clean to start). Can use help; laundry piling up rapidly. Thanx!:3:
Ok, open the top console, should be the 2 inner screws on top of the console, then the console will tilt forward. Unplug your washer first.
Some Maytag models have a fuse mounted on the lid switch bracket assembly, check to see if thet fuse is still good or not.
Some models have a white check switch, see if yours does.
The lid switch and check switch are on the same lid switch bracket assembly:
Manufacturer part number 22001682 is RepairClinic item number 1468
drsprackland
Oregon
Could not find lid switch bracket assembly. How can I upload a photo to show you my components board??
Sure, go right ahead.
Ok, sorry.
How do I attach a file to a post?
To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
What files types can I use? How large can attachments be?
In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing
after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
Jake <!-- / message --><!-- sig -->
Ok, yours doesn't have that fuse.
So you'd need a volt meter to check for 120 volts to your water inlet valve in the back of your washer.
Do you hear any humming sound when it trys to fill with water?
Remove the water inlet valve from the back, and remove the electrical connector from the cold side first and put your volt meter probes in the electrical connector turn the washer on cold water only and see if you get 120 volts.
