FIXED Old Maytag washer LA608 timer wires.
-austin-
michigan
LA608
The timer will not advance, the wires don't appear to be in the correct location. Having an issue with wiring up the new upgraded timer... (2-4476N) OEM (204476)
I don't have the wiring diagram for LA608, and I couldn't locate one online either.
Hopefully another tech or member that has one can post it here for you.
Thanks Austin.:)
RagPicker
Wisconsin
Here's the original schematic for the A608. The LA608 should be the same diagram. The "L" in LA608 represented an almond unit - which cost an additional $20 at retail.
If ever needed, I have schematics for the old Maytags starting with Models 160, A900, A902, A906
Thanks for the update Austin, was it just the wires in the wrong position on the new upgraded timer ?
Got it! Thanks Austin for clarifying that.(y)
Also thanks @RagPicker for posting the wiring diagram.(y)
