Old stackable washer/dryer need help to find a part!
krelvin
new orleans
Frigidaire
I believe this stackable is from 1988. Cant find any info on this appliance considering the age. It has been working for the past couple of months flawlessly and now the dryer stopped producing heat. I've taken the back cover off and the coil is in good working order so I think it must either be the hi-limit or safety thermostat. Just not sure where to buy replacements for such old parts. Any info would be appreciated... I'm posting a picture.20180720_114732.jpg20180720_114725.jpg
No, that thermostat you linked to is too high.
You need L200-70, I found one that will work here: High Limit Thermostat 137116700
Do you have a multimeter, because you will want to ohm test the thermostats to see if they show continuity before replacing them.
Watch this video to ohm test them here: High-Limit Thermostat Testing Video
Make sure the dryer is unplugged first before ohm testing them, also remove the wires from the thermostats too before ohm testing them.
