Mimicstudios
- YWED9300VU0
- Whirlpool
- More than 10 years
Hey everyone,
I sorted out some squeeky wheels/pulley on this dryer, but when I put everything back together, I got a F31 code and it won't actually start a cycle after hitting start. I hear the relay kick in, but cycle doesn't start. I realized that I didn't have the 3 connectors to the control board from the front panel connected when I first turned it back on? Did I overload something?
Have tried: measuring voltage at receptacle at wall, also had the snap connectors disconnected and measured 240V across the red/black and 120 with neutral/black and neutral/red.
Door switch seems to work (P3E on diagnostic).
Thermal Fuse shows continuity and thermistor around 12.65 kohms.
Haven't been able to test ghost voltage as there's no terminal block per se.
Any other ideas?
Matt
Any other ideas?
Matt
