Oster built-in microwave question: 220VAC on a standard NEMA 5-15P plug?
brucem
Ecuador
OJYE1201
Less than 1 year
I recently bought an Oster OJYE1201 built-in microwave. The manual states to supply it with 220V at 60Hz, yet the plug on the cable is a standard NEMA 5-15P. I thought NEMA 5-15P was only for 110VAC. I've written to Oster with no reply. Anyone seen 220VAC 60Hz (2 hot legs) presented on a NEMA 5-15P?
TIA!
Your in Ecuador?
Did you buy this in Ecuador?
I'm not familiar with Ecuador power or power outlets.
So why don't you go back to where you got it and ask them?
Quito
I have just buy the same microwave, also with nema 5-15 I tried with 110v and didn't warm the food, so plugged into 220v phase-phase-earth and is working perfect, the plug is not under the correct specifications.
