Oster microwave Replacing HV capacitor
synon
Arizona
Oster
I've got an Oster microwave I'm trying to bring back to life (it was abandoned). I'm pretty sure I've narrowed it down to the high voltage capacitor, I should have access to some better testing equipment tomorrow to make sure. I've found some HV capacitors, but they aren't an exact replacement to what's currently in the unit. The current capacitor is 2200v 1.0uF +/- 3%, how important is it that this is an exact match? Would a 2100v 1.05uF capacitor be fine?
