Oven Heating issue with Whirlpool Range model WFG510S0AS2
selkov
usa
WFG510S0AS2
A few weeks ago when turning on the oven the igniter would fire - the gas would light - and then go right out. It would not re-ignite.
I read online that the most common cause is a bad igniter. I replaced it and it worked fine.
Until now.
It will ignite and come to temperature but anywhere from 20 to 45 minutes the igniter will fire once and then the display board will blink like it has lost A/C power and of course it will no longer run.
If I reset the cooking temp it will run fine for another 20-45 min.
What do you think might be the issue?
It sounds like your oven control board is malfunctioning, thus that's why the board blinks like it has lost A/C power.
Here's the oven control board for your model:
WPW10424890 Electronic Control Board
